in my first experiments with the hierarchy beta feature, I see, that the connection fields are not visible. It's a little bit surprisingly, because in the list view they are visible.
It's not ideal for daily work, as the connection information is crucial.
Is this planned to implement in the near feature?
Best Thorsten
I don't get any notification that there was a reply to my asking. I think it is solved. Perhaps I was blind, or it takes a time, but now the linked issues (aka connections) are visible.
Thanks for letting us know!
Hi, what do you mean by "not visible"? thanks
