Created my first project and it is broken... help needed!
Antonio Valle (G2)
January 12, 2022
Hi!
I added Product Discovery to my site and then created my first project. It does not work, can not create issues, the demo issues are not presented and it is popping some errors
If I run a search on my project, I can see the list of initial issues created
And if I click on the generic "Create" button, I can create a new idea (as you can see in KIT-8) but nothing is shown in any of the views and the "Generic Error" image is presented
Any hint?
Thanks!!
Antonio Valle (G2)
January 20, 2022
@Tanguy Crusson just to confirm that the problem is solved and my site is working again :-) Thanks!!
Tanguy Crusson
January 20, 2022
Thanks for confirming @Antonio Valle (G2) !
Tanguy Crusson
January 13, 2022
@Antonio Valle (G2) thank you for reporting this, we're looking into it.
Tanguy Crusson
January 13, 2022
We're digging into it and haven't found the root cause yet, but were wondering if it was because the project failed during the onboarding (after you create it).
would you mind trying to create another one and see if this happens as well? We can help you clean up afterwards.
Like Antonio Valle (G2) likes this
Tanguy Crusson
January 14, 2022
@Antonio Valle (G2) is the error still happening for you? If so, could you please do the following so we can investigate further:
  • Try to open the project
  • when it fails, click on "share" (top-right)
  • select "anyone on the internet with the link can open this view"
  • Copy the link
  • Send it to tcrusson@atlassian.com
This would help us get to the bottom of this. thanks a lot!
Antonio Valle (G2)
January 14, 2022
@Tanguy Crusson
Hello!
I've deleted the previous project and created a new one. Same Errors.
I've shared the project with you, thank you very much!!
Vilius Zigmantas
Having similar issue - accessing PD project it loads, but after refresh of the page "dead link" error is displayed and there is no way to get to the PD project other than going to Jira project list and selecting PD project from the list.
Tanguy Crusson
January 13, 2022
@Vilius Zigmantas yours was another problem that we've just fixed. Can you please confirm opening the product via a link now works for you? Thanks!
Vilius Zigmantas
@Tanguy Crusson
Thank you very much for following-up on this. I can confirm that I haven't experienced the issue today.
Like # people like this
