Cross out insights
José Carlos De Oliveira Escalona
Is there anyway to cross out insights once you've used them/dealt with them?
When discovering and gathering information, I got a long list of inputs as insights.
Then I go thru them and use them shape the idea. But I don't want to keep reading the insights if I already got all usefull data from them, I don't want to delete them for future referecence.
Is there anyway I can mark them as "Done", "Used" or "Read" using a tickbox?
Kind of crossing them out from the the list
Tanguy Crusson
February 28, 2023
Great suggestion @José Carlos De Oliveira Escalona
What you could do for now, maybe, is add a label "done" to the insight? It's not a perfect solution but at least could help you see which ones you've already addressed vs not.
Thanks, that's exactly what I'm doing!
(I actually done the opposite with a label called "Outstanding")
Like Amanda Barber likes this
Amanda Barber
You can add a custom field with a checkbox and then filter out ideas based on that field. I do something similar with my status field - once it's marked as complete, it no longer displays on most of my boards. Then, I have one view where I display all of the completed ideas.
Thanks Amanda, but this is referring to the Insights section, inside an idea
Perhaps Attlasian can allow us to customise the Insights at some point in the future (like adding fields)
Amanda Barber
Ahh, apologies - replied before coffee today!
Cat Coffee GIF by Sam C:
Like Tanguy Crusson likes this
