Duplicate entries in Linked Issues menu
Seth Mason
In Project Discovery, in an idea, if I select "Linked Issues" I see two of each:
`has to be finished together with`
`has to be started together with`
`relates to`
Hermance NDounga
January 20, 2023
Hi Seth,
I've looked in my test project, and I also see two "relates to" - is it what you were referring to? I've added to our backlog as a bug. However, I am not able to find "has to be finished with" or "has to be started with" in the list.
Seth Mason
@Hermance NDounga I see this, which I collected while writing this response. To get this menu, I just click the "link" icon and click on the down arrow in the box to get the popdown menu.  I don't type anything.
Hermance NDounga
January 20, 2023
Thanks for the screenshot, I'm able to pinpoint where they come from 👍🏽 Thanks again for raising the bug
Like Steffen Opel _Utoolity_ likes this
Tanguy Crusson
January 19, 2023
Hi @Seth Mason , I think the issue here is that an issue link type always has 2 sides (e.g. "implements" vs "is implemented by"), so I'm guessing that for these 2 link types the 2 sides probably have the same name. Maybe the rest of Jira manages this differently and hides duplicates when that's the case? I need to check
Seth Mason
That's what I figured. Probably a typo error.
