Exporting Data in Jira Product Discovery issues with Formula Fields
Mike Gargano
So one of the issues I've been running into with Jira Product Discovery is if you use formula fields to make your RICE score or Priority score there doesn't seem to be a way to export that data.
So in JPD there is no option to export a list view as a CSV without using the Jira Cloud for Sheets or Excel extensions. Both of these options don't support Formula Fields. I can export data from JPD, but none of the new fields that are specific to JPD.
When I try to make reports for stakeholders we typically like to include some of these scores, and there doesn't seem to be any way to export this data that I can figure out. Has anyone figured out a work around for this?
4 votes
Tanguy Crusson
January 25, 2023
Hi @Mike Gargano it's not yet possible to export formula field values (the calculations are actually currently all done client side), but it's something we're changing - it's all moving to the backend, which means that at some point values will also be stored there, and so you'll be able to export them.
Mike Gargano
I appreciate the response @Tanguy Crusson and look forward to seeing that change in the future!
Michael Gardiner
@Tanguy Crusson any update on this?
