×Hi, we are enjoying our first steps in Product Discovery but want to push somethings up a level... for example:
Click on the grey bar at the top of the value column and choose sum (I've used Impact instead):
I think you would have to do that through Jira Software (see Rollup story points to Epic level ) and set the delivery progress field to show story points not issue count:
I don't think this is currently possible, but someone else may know better
Hey, thanks Stephen. I did not realize that we could have some aggregations already on the table value. I was trying to build a Dashboard but this is a great step forward already!
Does not look like we can use that technique to aggregate the story points or number of issues though. That would have been nice so we could see effort vs value : ) Effort as in the effor of the linked Jira tasks, not just the estimated effort of the idea object.
https://www.youtube.com/watch?v=X9SFmCdKe0U
Hi @Shawn_Giese
For assigning an idea to non-creators, you could create a new user field and have that contain the person you want to 'assign' the idea to, then create a filter that filters by that field you created being the current user. You can then share that filter, or a board using that filter, with the people you want to assign stuff to. It is not a true Assignee, but it might work? Or you could simply have that field available as a filter in your view in JPD directly. You can then also 'assign' more than one person.
To allow users to click something to indicate if they have reviewed, you could add a 'reactions' field you name appropriately and then ask them to put a thumbs up or smiley or whatever you prefer to indicate that they have reviewed. You can then see who has done this.
Also, Delivery Status rolls up all the Story points of the Delivery Tickets in your Idea if you set Delivery Progress to Story points, like @Stephen_Lugton suggested. So you could show that field to show the total of the story points.
Hovering over Delivery progress bar, shows you the total as well, the Delivery status shows the story points in each status category (To Do, In Progress, Done)
Hi @Shawn_Giese ! thank you for embarking on the JPD journey
Hope this helps!
Amina, JPD PM
