How to split an Idea into smaller child ideas that each map to epics?
Paul Reeves
January 20, 2025
Hi all,
I'd like to get some advice about how to best document an Idea hierarchy in JPD. For example we have a large Idea which needs to be split into child ideas( or something) each with their own specific documentation within JPD. These child ideas should then each be mapped to an epic in Jira,  always under the umbrella of the parent idea. Each of these epics ultimately represents a unit of release.
What's the best way to achieve this?
Thanks in advance.
Paul
2 accepted
3 votes
Bill Sheboy
January 20, 2025
Hi @Paul Reeves -- Welcome to the Atlassian Community!
What Jira license level are you using?
There is an early-release-only JPD for Premium license customers that has Idea hierarchies: https://community.atlassian.com/t5/Jira-Product-Discovery-articles/A-giant-update-for-hierarchies-issue-types-opportunity-solution/ba-p/2893631
Without that feature / level, there is nothing built-in to support what you ask.  A workaround could using multiple Ideas with issue links to connect them...although filtering may be challenging as only the linked-issues count could be checked.
Paul Reeves
January 28, 2025
Thanks, great to know
Like Bill Sheboy likes this
Tanguy Crusson
May 5, 2025
Hi there: you can now start creating custom product hierarchies (e.g. Opportunities-Solutions, parent-child and more) using a feature from the Jira Product Discovery Premium plan.
About the feature:
About the JPD Premium plan:
