JPD Automation for Confluence pages sync to Idea Pages Field
Pierre Liddle January 27, 2024
I would like to know if it is possible that once a confluence page has been created with JPD automation, that the page link is updated in the Idea pages field for easy reference.
Basically, I want the original Idea updated with the link to the page that was created via the automation.
Hermance NDounga
January 29, 2024
Hello Pierre,
First you would need to create a field type "Hyperlink". I named mine "Hyperlink" in the rule below:
1. when an idea is created
2. Create a confluence page that has the same name
3. Place the link of this page in the field hyperlink for this idea.
Here is the rule : Screenshot 2024-01-29 at 11.09.36.png
And here is the result
Hermance NDounga
January 31, 2024
Sorry, I just fixed the permission on the video, you should now be able to see it :)
Pierre Liddle January 31, 2024
Thank you Hermance NDounga that worked perfectly!
Like Hermance NDounga likes this
