hi @Denis Brum are you still experiencing the issue? As the error suggests, this seems to be an issue with your login provider.
Hi @Rohan Swami
Yes. I'm still experiencing the issue.
How can I resolve this with my login provider?
Hi @Denis Brum this isn't an experience within Jira Product Discovery. I suggest you you reach out to Atlassian support support.atlassian.com/contact
@Denis Brum , Hi, I'm meeting the same issue here, did you solve your problem now?
It has to do with license privileges. At this moment I have Basic License and Kibana wiil only connet to Jira if you have Platinum or Enterprise licenses.
