Project Start and Project Target on List View Shows Wrong Quarter Months
Jess Jose July 28, 2025
We select quarters for our Project Start and Project Target. When displayed on the list view, the months being shown for the quarters do not match what we have in the Dates configuration for JPD. It shows 4 months instead of 3 and overlaps with other quarters. The picker shows the correct quarters but when picked, the description on the list view shows the 4 months.
Here is the Date Picker:
Here is the list view with the wrong months (4 months for the quarter) and with the overlaps with other quarters. This should show Jul-Sep, 2025 and Oct-Dec, 2025.
Here is the Dates configuration for JPD:
This was working previously (in the last few weeks). I only noticed this new issue last week.
It seems like a bug. If not, is there a configuration I am missing? Like I said, this was working until last week.
Bill Sheboy
July 28, 2025
Hi @Jess Jose -- Welcome to the Atlassian Community!
Did you recently change your quarter settings?
If so...My understanding is when the settings are changed any existing "quarter date range" values in Ideas need to be manually updated to reset the value.  It does not happen automagically.
Hi, Bill. No, we didn't change it. The settings has always been the same as out-of-the-box.
When I started having problems, I did go to the Dates settings, I didn't change it and clicked Save. But that still didn't fix the issue.
I did go to the Ideas and manually changed the values and saved them. No luck on that either. I also added new ideas and selected quarters. Same issue.
Thank you.
Bill Sheboy
July 28, 2025
Thanks, and I should have tried that first as I see the same defect:
  • When selecting the quarter, the dates are correct
  • When displayed in a list view, the first month is off by one
  • The data behind the scenes (in the JSON) is correct
I recommend asking your Site Admin to submit a ticket to Atlassian Support: https://support.atlassian.com/contact/#/
And we can see if @Beata Kupiec who wrote that announcement knows about this one.
Beata Kupiec
July 29, 2025
Hello @Jess Jose welcome and thanks for reporting the issue. The team will look at it, and as we are not able to reproduce please make sure to submit a ticket via: https://support.atlassian.com/contact/#/.
Beata Kupiec
Principal Product Manager, JPD
Bill Sheboy
July 29, 2025
Hi @Beata Kupiec
FYI -- When I retested this morning with the same fields and same work items, the symptom no longer appears in the JPD list views.
Jess Jose July 29, 2025
Hi, @Beata Kupiec and @Bill Sheboy ,
I re-tested just now and it looks like the issue I have has been resolved. We didn't change anything on our end but as of today the problem we were having the past week is gone. See below.
Thank you for the quick responses!
Like Bill Sheboy likes this
Beata Kupiec
July 30, 2025
@Jess Jose @Bill Sheboy thanks for info, we had to revert the feature to fix it  so you see no issues now. It will be back soon. Could you please let me know what time zones you are located? This is might be a root cause for the issue.
Bill Sheboy
July 30, 2025
@Beata Kupiec -- I am using the Pacific time zone (US) for this Jira site.
Jess Jose July 30, 2025
@Beata Kupiec  we are using Central Time Zone (Chicago). Thank you!
Beata Kupiec
July 31, 2025
Thank you @Jess Jose @Bill Sheboy  the fix is on the way. Thanks for all your help and context provided it helped a lot!
