Removing decimal places on the Jira Product Discovery board
Oksana Oliinyk January 17, 2025
Is there a way to remove decimal places from the results of a custom formula displayed on the Jira Product Discovery board?
Bill Sheboy
February 1, 2025
Hi @Oksana Oliinyk
That is not possible with the built-in formula feature of Jira Product Discovery (JPD) fields.
One workaround is to use an automation rule to perform the calculation (when the source fields change) and then round the result into a custom field.  One limitation of this approach is it cannot use other formula or "rank" fields in the calculation.
If you want to try this approach, please see this information to get started: https://www.atlassian.com/software/jira/guides/automation/overview#what-is-automation
And if you run into challenges creating the rule, please post an image of your rule and explain what is not working as expected.  Those will provide context for the community to offer better suggestions.
Valerie Knapp
Hi @Oksana Oliinyk , welcome to the Atlassian Community and thanks for your question.
Please can you post a screen of what you mean? Of course you can anonymise any sensitive information.
Best wishes
Amina Bouabdallah
January 21, 2025
Today we don't have a feature to crop decimals or round a decimal number to a floor or ceiling. Is that what you are looking for?
Like # people like this
Oksana Oliinyk January 31, 2025
@Amina Bouabdallah yes, this is what I was looking for, thank you!
