When I try and set up this integration for this project I consistently get an error saying "You cannot edit the configuration of this project.".
Digging in further I'm told "App does not have write access to the project" and I should edit the Permission Scheme granting all permissions to the Project Role atlassian-addons-project-access
. I've tried editing the defaul permissions scheme, but I cannot find a permission scheme that is specific for my Jira Product Discovery Project, which I'm thinking is the issue.
Has anyone else been able to solve this?
Hello Steve !
I've just chatted with our support team and they let me know that they surely can fix it for you :)
Could you please open a ticket https://support.atlassian.com/contact/#/ - make sure to select Jira Product Discovery as the product and place your site URL
and they'll reach out back to you !
Best Regards,
Hermance
Product Manager @ Jira Product Discovery
Thank you. I've submitted a ticket.
@Hermance NDounga , I'm having the same issues and cannot create a support request (automatically being referred to ask a question in the community.
Trying to move my team into Product discovery from a different product and the slack integration is a must for us.
Can i ask for an assistant so i will be able to complete the evaluation?
Thanks.
@Hermance NDounga I am having the same issue noted above with the slack integration and like Gilad, I am unable to raise a ticket.
Whats the best way to get this permission issue remedied?
Best, DC
Hey @Gilad Waldman @Diego
Can you please use the button "Give feedback" and select support team?
This will create a support ticket
In July 2024 we're having this issue also. Is there a solution other than raising a 'Give feedback' ticket? The permission schemes for these is non existent...
