Template for a Project in Jira Product Discovery
Karina Paula-Freimane October 9, 2024
Is it possible to create a new template for a project in JPD?
We use Jira Product Discovery for roadmaps. Roadmaps are created for each of our clients, so for each new client, we create a new project in JPD.
Right now, we use the "Blank" template, and each time we need to spend some time adding all the standard views, fields, etc. My colleagues are asking if there is a possibility to copy projects, share settings, or create new projects from a template.
2 accepted
Tanguy Crusson
June 11, 2025
Tanguy Crusson
October 9, 2024
Hi @Karina Paula-Freimane you can't yet create custom Discovery project templates but we have one team currently working on something for this:
Tanguy Crusson
October 9, 2024
Hi @Karina Paula-Freimane you can't yet create a custom project template but we have a team working on it:
Karmela Cortez
January 24, 2025
Hello! Wonder if this is still in your roadmap? thanks!
Karina Paula-Freimane January 24, 2025
My company is also waiting for it :)
Tanguy Crusson
January 24, 2025
Yep, still working on it.
Like anastasia.razavi likes this
Karina Paula-Freimane November 15, 2024
@Tanguy Crusson  Thanks you, could you please provide a release date, when we can expect this solution?
Tanguy Crusson
November 18, 2024
Hi Karina, we don't generally communicate ship dates. When we do it's usually when we're 2-4 weeks away from shipping. We do have a team working on this currently.
Jeny Stoeva
October 9, 2024
@Karina Paula-Freimane ,
From your description I am understanding you are organising your work in projects which are represented by different Views in JPD and you want to be able to use one of those Views as a template.
You can easily do that by just selecting the View and using one of the "save as..." options available via the 3 dots menu. Using one of them will create a new View for you with the same fields and if you have a Project field then you have to just filter for your project in order to populate the view with the relevant for it tickets.
Katie McDaniel
@Jeny Stoeva Hi - could you tell me more about this? I think the original ask was to reuse a view as a template across multiple JPD projects, or create a custom project template with the correct views. Is that what you're describing here?
If that's possible, I definitely want to know about it!
Jeny Stoeva
February 27, 2025
@Katie McDaniel Hi, nope, I've been talking about the views available in a JPD Project and not a template view for creating a Project. @Tanguy Crusson mentioned they've been working on it but I am not sure whether it has already been released.
I found this link though but again not sure if it is relevant for to the JPD project type: https://developer.atlassian.com/server/jira/platform/creating-a-project-template/
sureshr
STILL THE OPTION IS NOT AVAILABLE TO REUSE THE EXISTING PROJECT AS A TEMPLATE TO CREATE NEW PROJECT?
Tanguy Crusson
May 19, 2025
Hi @sureshr , it looks like your Caps-lock got stuck?
We're currently rolling it out. It's currently available in 20% of sites, and the rollout should complete in the next few days.
Jan Wilson
May 20, 2025
Hey, This is great news, if you are saying that the ability to 'clone' an existing JPD project to create more is being rolled out now. Is that what you are saying? If so, how will we know if we are (or could be...) one of the lucky Atlassian clients to get this new feature (soon)?
Tanguy Crusson
May 21, 2025
By end of week everyone should have it.
projects > create project > product management section
Like sureshr likes this
Naren Shivadas June 10, 2025
@Tanguy Crusson Has this feature been released yet? I don't see the 'Save as Template' option available for JPD Projects
Tanguy Crusson
June 11, 2025
