Hi All,
As Product Discovery matures into a shipping product, it would be good to see roadmap view (like in Advanced Roadmaps/Project roadmap) and the true nested hierarchy features release (as are discussed in other questions on this thread). We currently utilize another product (Aha) for some of these features, but would like to consolidate into the Atlassian ecosystem.
Is there a "roadmap" for the beta of the product to be able to understand the features that are planned, and relative timeframes? Also, are there plans for importing roadmaps from other projects, or at a reverse sync from Jira to populate a Product Discovery project?
Thank you
Hi there: you can now start creating custom product hierarchies (e.g. Opportunities-Solutions, parent-child and more) using a feature from the Jira Product Discovery Premium plan.
About the feature:
About the JPD Premium plan:
Hi Ken, and thank you for your feedback! You pack a lot in a single message :)
Roadmaps
Today you can create roadmaps using lists and boards, which is what most teams do. It applies quite well to roadmaps which are not time-based (e.g. Now/Next/Later). For the team that want to rely on time-based commitments in their roadmaps, we are working on a timeline view, which would look like this:
What you'll notice though is that this view is also abstracting away from the details. Its goal is to help you share and collaborate on product roadmaps that explain the "why" (why are we focusing on this? which goal does it contribute too? etc.) and help give a general (loose) sense of timing. It is not meant to be used to create detailed delivery roadmaps which typically provide a breakdown of tasks - for this we recommend using the delivery roadmap features in Jira Software, or Advanced Roadmaps.
Nesting ideas / idea hierarchy
Jira Product Discovery has a different approach to products created by other vendors in this space when it comes to organizing ideas. Instead of a hierarchical model you can make use of the flexible views and fields structure to visualize your ideas based on a number of dimensions.
Demo: using fields and views to organize a large list of ideas
You can use this to create a parent/child or opportunity/solution relationship, but it takes a bit of ninja skills today and we plan to make this easier to work with:
Demo: grouping solutions by opportunities. And here's a recording for how to reproduce this configuration
Importing ideas
We plan to make importing ideas easier, including from other Jira projects. Today you can import ideas in 2 ways:
Jira Product Discovery's roadmap
We're not currently sharing the full product roadmap (and we don't communicate timeframes), but you'll find updates in the community fairly regularly. The problem areas we're currently looking at:
Following this, we currently plan to focus on a better way for product teams to collaborate with other teams, users and customers.
Thank you Tanguy for the information. Looking forward to working with the timeline view, as well as exploring the relationships capabilities that you described.
Hello @Tanguy Crusson
When will this timeline view will be available ? This is a feature I have being looking for .
@Erion Peci I don't know when it will be available yet, but we are going to start working on it in the next couple of weeks
Any updates? The tree hierarchy is a deal breaker for me - if it's not there, I won't use it. Even if I have to maintain my trees on Miro (I live in Miro most of the time anyway). I am so over flat lists or nested lists. They are still lists and aren't useful.
Hi @Helena Jeret-Mäe , not yet - the same solutions are still what we recommend today.
@Helena Jeret-Mäe That's a great question! Actually: yes
I'm actually doing a webinar where one of the topics is that one: https://www.atlassian.com/webinars/software/how-to-uplevel-your-product-discovery-practice-with-jira-product-discovery
@Tanguy Crusson OK, I'll check out the webinar. I'm going to try some parts of it but contextual structure I will keep in Miro for now.
I guess I'm having PTSD from years of flat backlogs. :D I also like to visualize a lot so it would be easier to understand what's going on. Over the years I've tried RICE and other ways of adding stuff to matrix but... it's not the same as the OST structure that really helps to see where the opportunities cluster and how they are distributed across a user flow (at least I follow this structure to retain coherence).
