what is the cost of Product Discovery Premium on top of Product Discovery Standard for 11 contriubutors
Welcome @Jan Vanherck
Contributors are free, however creators are being paid. For premium 11 creators, the cost is 25$ per creator a month. You can use the calculator from this site: https://www.atlassian.com/software/jira/product-discovery/pricing#
Hi @Jan Vanherck ,
if you upgrade from JPD Standard to Premium, then all of your JPD licenses will need to be Premium. You can't mix Standard and Premium licenses on the same product.
To check the price of the Premium licenses, you can have a look at this calculator : https://www.atlassian.com/software/pricing-calculator
If you're on monthly billing then you'll just see the new price on your next bill.
Let me know if this helps,
--Alexis
Hello @Jan Vanherck
You can check the pricing details https://www.atlassian.com/software/jira/product-discovery/pricing
That would be 25$ per creator/month; you cannot have partial standard or premium; it would be either or !
Contributors doesn't consume license, creator done only
