Good day, guys!
I'm trying to automate the creation of some Ideas in a Jira Product Discovery project.
The original data comes from a Jira Service Management project, and through an automation, I'm trying to set the Value, Effort, and Impact fields in Product Discovery.
E.g.:
Let's say I have 3 fields:
I've created an automation to retrieve the value from these fields, convert it into a number using a Lookup Table, assign it to a variable, and then attempt to set the value for the Rating fields from the Product Discovery project.
It returns the error below:
For a question like this, context is important for the community to help. Please post the following:
Until we see those...
What are the types of your JPD fields which you are trying to set?
If those are calculated fields, they cannot be set as the value are not actually saved in the Idea: they are dynamically calculated for display only. If they are other field types, setting the specifics for your rule will help identify the cause of what you observe.
Hi @Gustavo Moraes , thanks for your post.
I also had a look at this as I was interested in this topic.
I don't see any examples in the template library to create from another product into JPD. Instead they are from the other way around, where the JPD closing would open a Jira work item.
I checked this also - https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/ but I don't find the JPD fields in the custom field settings so I am going to ask Atlassian about this.
They should reply to us here in this post.
Best wishes
