Is it possible to create a new template for a project in JPD?
We use Jira Product Discovery for roadmaps. Roadmaps are created for each of our clients, so for each new client, we create a new project in JPD.
Right now, we use the "Blank" template, and each time we need to spend some time adding all the standard views, fields, etc. My colleagues are asking if there is a possibility to copy projects, share settings, or create new projects from a template.
Hi @Karina Paula-Freimane you can't yet create custom Discovery project templates but we have one team currently working on something for this:
Hi @Karina Paula-Freimane you can't yet create a custom project template but we have a team working on it:
Hello! Wonder if this is still in your roadmap? thanks!
Yep, still working on it.
@Tanguy Crusson Thanks you, could you please provide a release date, when we can expect this solution?
Hi Karina, we don't generally communicate ship dates. When we do it's usually when we're 2-4 weeks away from shipping. We do have a team working on this currently.
@Karina Paula-Freimane ,
From your description I am understanding you are organising your work in projects which are represented by different Views in JPD and you want to be able to use one of those Views as a template.
You can easily do that by just selecting the View and using one of the "save as..." options available via the 3 dots menu. Using one of them will create a new View for you with the same fields and if you have a Project field then you have to just filter for your project in order to populate the view with the relevant for it tickets.
@Jeny Stoeva Hi - could you tell me more about this? I think the original ask was to reuse a view as a template across multiple JPD projects, or create a custom project template with the correct views. Is that what you're describing here?
If that's possible, I definitely want to know about it!
@Katie McDaniel Hi, nope, I've been talking about the views available in a JPD Project and not a template view for creating a Project. @Tanguy Crusson mentioned they've been working on it but I am not sure whether it has already been released.
I found this link though but again not sure if it is relevant for to the JPD project type: https://developer.atlassian.com/server/jira/platform/creating-a-project-template/
