Jira’s fresh look and navigation
74 comments
Aline Veyradier
Hello @Wurm Peter ,
I agree with that, that's what's happening.
But that's not what I'm asking. My problem is that I can't access the feature shown below BECAUSE it opens a board and not the project.
Wurm Peter
@Aline Veyradier When you click on "..." next to "Test BP Scrum" in your left sidebar, you do not get that option?
Aline Veyradier
@Wurm Peter
No, I don't ! Therefore, I am unable to access to More actions (...) in the header of the project, only for software projects. It works well for business projects.
Aline Veyradier
I just made a new test ...
I created a software project named "Test nouvelle navigation" without creating an associated board. In this case, I am able :
  • to select the project from the sidebar,
  • to access to More actions (...) in the header of the project,
but I still don't get the feature Set project background.
And as soon as I create a board associated to this project, I loose all the possibilities I mentionned before, because I'm automatically brought back to the board.
Like Don Arsenault likes this
Osama Al-Areky April 29, 2025
hello can please someone help me know how to post a post in this forum? this is so freaking funny, i am not able to find a button to creata a new post; first time ever i see amazing user experience like this
Varsha Patel
April 29, 2025
@Piotr_Śmiałek_Deviniti
We're currently shipping a lot of changes to Atlassian products that are in early stages (Early Access Program) which we will make available in our Figma files as the solutions become more stable and move to Beta and GA over the coming months. We'll let you know when these resources are available.
Christophe VERGNE
May 12, 2025
The new navigation is pretty refreshing, but the look of "blue" and "green" status are difficult to read compared to before the change.
In a large view like the screenshot it's barely ok, but in a smallest view the previous version was way more easy to read with the previous contrast (even if I'm surprised the actual constrast is ok in accessibility terms).
Am I the only one disturbed by this change ? Is it possible to do something ? I saw some people asking custom colors but maybe is it possible to give the choice between previous version and new one ?
Thanks !
Like # people like this
blockchainmaster3000
May 21, 2025
Feedback of our users "The new design introduces a more minimalistic visual structure. While the top menu now blends more seamlessly with the board, it may take some time to adjust to the subtler separation. The updated work item icons have a lighter, more modern look, which might require a bit more focus to distinguish at first. For users with visual or concentration challenges, this change could present an initial hurdle. Personally, I find the interface now has a more uniform, neutral tone that may benefit from a bit more contrast to enhance clarity."
Cédric Daemen
Hello all,
Just wanna talk about this new layout.
I'm sorry but the old one was way better, is there a way to swap to the old one?
Cause this new layout ain't user friendly at all...
CamB
May 29, 2025
Bug: Pressing "hide" or "customise sidebar [uncheck projects]" has no effect. Project list still shows.
    [edit] after 24 hours, it now hides the Project list. Maybe Atl rolled out an urgent fix, maybe the code failed to manage browser-side cache properly. At least it works.
Bug: Using the ^ to minimise the project list is only effective until reloading the screen or opening another work item - when the list expands again, automatically.
Poor UI:
(1)
Using [>] to hide the sidebar entirely is only effective until needing to use the sidebar to navigate (e.g. to dashboard)
(2) losing the top-menus means we can't avoid using the side-bar. We are also wasting time searching all over the screen for UI items, which is very awkward.
(3) it also reveals if accidentally moused-over (should require a click).
PLEASE allow us to switch back to the old nav GLOBALLY by an admin!
May Malpas
June 4, 2025
It. Is. Awful.
Diane Logsdon
I've been using the new navigation for several weeks now, and I like it less with each passing day.
It is annoying to have to continually expand/minimize the menus on the left to get to the projects, filters, dashboards, etc. that I use frequently, even if starred. It's decreased my efficiency.
To have to scroll down to the bottom of any topic (dashboard, filter, project, etc.) in order to "view all" is insane. The Projects is the only menu that gives the option with the three dots (...) to "manage projects", why isn't that available for EVERY topic?
Having it on the left pane wastes precious browser window space, requiring me to expand the window more than it used to or is functional. How do people handle this who don't have wide monitors, like when using a small laptop? I can't see how that is functional for anyone.
What problem(s) was these changes supposed to be solving? My vote is to reverse these changes. This was a horrendous mistake and Atlassian did not sample a broad enough cross section of its customers before deciding to push forward with this.
David Tieman
@Diane Logsdon  You are 100,000% correct regarding using this new navigation layout on a laptop monitor...  it's IMPOSSIBLE to use.  This layout has reinforced my use of browser tab Groups with links to each JIRA view I use... i.e. 1 tab for my Scrum board, 1 tab for the Filter of the related issues, 1 tab for the Reports, 1 tab for the JIRA Plan Timeline view, etc.
One other "oddity" is that when there is room on the menu bar for the Shortcuts to be displayed, there is no way to show those other than selecting the dropdown, i.e. multiple clicks.  I removed options such as Timeline, Goals, Forms, Code, etc.  to have more room to see if I could display the actual shortcut link instead of having to 1st click on "Shortcuts"... :-(
Don Arsenault
@David Tieman , Thanks for your insight. I was wondering if using browser bookmarks, windows, tabs, and tab groups would alleviate some of the pain with Jira's new nav. Seems like orgs with lots of projects are the ones hurting.
I have not experienced the new nav yet. I expect it's coming to my org next month.
Darryl Lee
Hey y'all. Looks like Atlassian is looking for direct feedback. I'd recommend signing up:
While we’ve seen strong quantitative success (like low opt-out rates and solid usage), we want to dig deeper into how the experience feels and functions in your day-to-day workflows. We’re opening up a research study for users and admins who have used the new navigation for at least two weeks.
Like Josh likes this
David Tieman
@Don Arsenault  I have been using the Browser Groups and Tabs for a long time as I have 10+ JIRA projects that I am actively engaged in.  That doesn't include another Browser Group for Automation tab links for each of those projects.  I was hopefully for some other benefits from the new navigation to reduce this need and setup.  I guess that the one option that I would like to have would be to "hover and click" vs. "click and click".
Aline Veyradier
It seems that this release note has disappeared from the Jira roadmap : Introducing Theming: Add a splash of color to your projects
the page no longer exists.
Jeremy Nydegger
Really struggling to understand the benefit of forcing users to navigate to a project's board(s) first instead of going straight to the list of issues.  We have a number of teams that work straight within the projects themselves and don't utilize a Kanban board for their way of working.  The default when navigating to a project from the "Recent" list in the left-hand navigation should be the normal default project view with the option to select the drop-down arrow to go to a board if present.  The fact that currently you can click directly on a project without a board yet created, but are forced to select a board for other projects that already have one is very unintuitive in my opinion.
Austin Songer
So I'm using this same comment on any page that talks about this horrible new Navigation.
I have to say it this new navigation is terrible. I honestly don’t understand why Atlassian would think it’s an improvement. It’s baffling, and it really sucks that you’re forcing everyone to use it. There are so many other areas that could use improvement, but instead, you decided to change the navigation which was already working just fine. This feels like a classic case of ignoring the saying, “If it ain’t broke, don’t fix it.” Now, the new navigation is confusing, and I can’t see any reason why you’d make this switch. It’s just bad.
Jesenko Bajovic
Recent Cloud Jira & Confluence UI changes: critical feedback
Atlassian built its brand on engineers serving engineers. Abrupt UI overhauls—and removal of critical functions—are very misaligned with that heritage. We/I will also evaluate alternatives for all future efforts.
I’ve championed Jira and Confluence since 2004; they remain powerful products. But disruptive changes without adequate communication jeopardize user trust. I hope Atlassian re-engages with its core audience before more teams are forced to look elsewhere.
David Tieman
Will an option be available for a Project wide setting option that can be configured for all users of the project?  Users would still be able to make changes for their view but based on the project wide setting.  Basically I want to have all of the Shortcuts listed on the view for all users, I don't need Forms, Security, Archived Work Items, etc.  And I don't want all of the project users have to make the same changes.
Thank you
Karen July 27, 2025
Would be good if 'Starred' is a drop down (like Projects) instead of to the side.
Prefer not to click on 'Starred' every time I want to go places that I visit often.
Wurm Peter
I would prefer if all menu items expand to the side (a new popup window). But not on click, but on mouseover.
Darryl Lee
Hey'all, there's a feedback request here for non-admins:
Seeking END-USERS to help us improve Atlassian’s navigation
As an extension of our previous admin-focussed research into the new navigation, we're eager to hear directly from end-users (non-admins) to ensure we capture a complete picture of how all types of users are experiencing the changes.
As a reminder, we're looking for users who:
  • Are not administrators of any Atlassian products (project administrators are fine, but no higher levels please)
  • Have been using the new navigation for at least 2 weeks
  • Have been using Atlassian products/apps for at least 12 months
  • Use any of the following products:
    • Jira
    • Jira Service Management
    • Confluence
    • Atlassian Home
  • Are comfortable with video, audio, and screen sharing with their own sites and real-time data
Admins: If you know any vocal or engaged users in your organization, this is a great opportunity to send them our way! Please encourage them to participate by sharing this link: https://www.userinterviews.com/projects/jd_TbgvaGQ/apply
Thank you for helping us make the new navigation work better for everyone.
Aditi
