Have you ever worked on a project and felt like it was just too much to handle all at once? We've all been there! That's why Jira is here to help. In Jira, we like to think of a project as a đȘ magical container that can hold all of your tasks and help you keep track of them. These tasks are called "issues," but don't worry - they're not as scary as they sound! By organizing and tracking your issues in Jira, you and your team can work together towards achieving your goals more efficiently and stress-free.
Jira Software is an amazing tool for teams to track and resolve bugs, launch new features, and so much more. Projects are highly configurable and can be easily customized to fit your team's unique way of working, regardless of your organizational structure, workflow, or level of agile maturity.
Your projects are in the top navigation in the âProjectsâ drop-down.
When it comes to any project, there are always a bunch of tasks that need to be done, people who are making things happen, and processes that help move that work forward.
In Jira, projects are like big goals that have been broken down into bite-sized pieces of work called 'issues.'
Jira Software makes it easy for teams to plan and track work together so that you can get more done. Plus, you can invite your teammates to your Jira project and work together seamlessly.
To ensure your team is always on track, Jira projects follow a process or workflow that helps manage issues from start to finish. Don't worry; these workflows can be customized to match your team's unique way of working.
Templates
If you're looking for a quick and easy way to set up a project and jump right in, Jira has got you covered with several project templates that are tailored to specific teams or use cases. These templates come with pre-configured issue types, workflows, and other relevant features so you can get started right away. If you're not sure which template to use, the Kanban and Scrum templates are two of the most popular ones. You can check out the Jira templates library for more information.
Project Types
Select âCreate Projectâ from the top navigation in the âProjectsâ drop-down.
Note: You wonât see this option if you donât have the permissions <LINK> to create projects
While there's no one-size-fits-all approach to structuring projects in Jira, it's crucial to remember that Jira projects are built for ongoing efforts, not single-shot endeavors. This guide outlines key strategies to help you decide how to best organize your project in Jira:
Remember, these are starting points! You can get granular or broad, like segmenting your product structure by individual features (think dividing your main objective into smaller sub-tasks).
Key Considerations:
Remember: Experimentation is key! Different structures may suit different projects. Be flexible and adapt based on your specific needs and team preferences.
By taking these considerations into account and exploring the available options, you can create a project structure in Jira that empowers your team, streamlines workflows, and ultimately leads to project success.
For an even more detailed explanation for how to get started (without this gamified flair!), check out this fantastic Jira Software Getting Started Guide!
Amanda Barber
Product Manager / Professional Cat Herder đž
GradeCam
Greenfield, WI
51 accepted answers
11 comments
