  • Community
  • Q&A
  • Jira
  • Questions
  • Автоматически установить тему связанной задаче и добавить к ней тему родительской задачи
Regina Andr November 13, 2023
Как автоматически установить тему связанной задаче и добавить к ней тему родительской задачи
Ram Kumar Aravindakshan _Adaptavist_
Hi @Regina Andr
The approach you are taking will not work.
If you intend to update the Summary according to the Linked Issue, you must use the Condition field instead of the Additional issue actions field.
I have run a basic test in my environment and got it to work. Below is the sample code that I have tested with:-
import com.atlassian.jira.event.type.EventDispatchOption
def mutableIssue = issue as MutableIssue
def summary = mutableIssue.outwardLinks.last().destinationObject.summary
def issueManager = ComponentAccessor.issueManager
def loggedInUser = Users.loggedInUser
mutableIssue.setSummary("Example ${summary}")
issueManager.updateIssue(loggedInUser, mutableIssue, EventDispatchOption.DO_NOT_DISPATCH, false)
Please note that the sample code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
Below is a screenshot for your reference:-
I hope this helps to solve your question. :-)
Thank you and Kind regards,
Ram
Regina Andr November 15, 2023
Большое спасибо!
