Hi all
I had used Jira 4.4.4 version. Present I have upgraded it to Jira 5.0.2.
Some function is so good. But activity stream funcion in project is not!!
I make prroject key alphabet, number and special character "_" for seperating words (ex, XX_XXX_XXX). I know that's not recommanded. But I must make like that :(
Version 4.4.4, I can use activity stream without problem. But version 5.0.2, activity stream does not load in project. If project key is normal, activity stream is working. In case of abnormal, it isn'. I think when filering activity stream with project key, it makes problem.
In dashboard gadget, same work with proejct activity stream, if no filter set for project, gadget is working. but set a project filter with abnormal project key, it doesn't loading activity stream .
How can I solve it??
Your choices are simple
Activity Stream plugin doesn't support underscore. I hope that support underscore in the foreseeable future
