Adding a mention in comment using JIRA automation
Ayoosh Gupta
March 3, 2025
Hi
I've been trying to mention the "Approver" in the comment using JIRA automation but I always get "@unknown". Been using the correct syntax using the account ID and have doube checked the execution rules and the access for my ID and the JIRA automation user but still fails. Any tips? Has anyone got it working for them?
Post a new question
SilkeS
Community Manager
October 14, 2025
This topic has been locked because the thread has become a bit dated. If you’d like to keep the conversation going or have additional questions, we encourage you to start a new topic. You can read more about necro posting (“raising threads from the dead”) in our  Community Guidelines .
Thanks!
Sebastian Pechhold
I wanna do this with the reporter and using
[~accountid:${{issue.reporter.accountId}}]. But i get "@unknown" as mention text. Doesnt matter if i am the rule actor or not. I am org admin as well.
Prachi Bolar
March 3, 2025
Hi @Ayoosh Gupta
Welcome to community :)
Please chcek if your use case is similar to this :https://confluence.atlassian.com/jirakb/jira-service-management-cloud-use-automation-rule-to-notify-pending-approvers-1443041080.html#
Thank You,
prachi
Vishal Biyani
March 3, 2025
The format for @mention to work is
[~accountid:{{issue.assignee.accountId}}] or replace the bold values with your fields.
However, as Rebekka rightly mentioned, sharing what you have put in place so far and the audit logs will help in analyzing the problem
Rebekka Heilmann _viadee_
Hi @Ayoosh Gupta and welcome to the Community,
could you provide screenshots of the rule (actions) that you got so far? That always helps with analyzing where it goes wrong.
Bill Sheboy
March 3, 2025
Hi @Ayoosh Gupta -- Welcome to the Atlassian Community!
Adding to the suggestions from @Rebekka Heilmann _viadee_ ...
The Approvers field is a list of values, and so a rule would need to iterate over the values to add each one using the mention syntax.  For example:
{{#issue.approvers}}[~accountid:{{accountId}}]{{^last}}, {{/}}{{/}}
Post a new question
