After adding components, component field is not visible
Gabriel Heiler September 26, 2018
So I added a some components to my project (before there were no components), but the component field is not visible when creating/editing an issue. What could be the problem?
Mohamed Benziane
Hi @Gabriel Heiler
Take a look at you create screen and edit screen in your screen scheme and make sure the component field is not hide in your field configuration
Regards
Where should this screen scheme should be? Do you mean this one? The component field is also not shown there.Screen Shot 2018-09-26 at 14.29.10.png
Mohamed Benziane
Pete Singleton
September 26, 2018
You will need to edit the Screens (Create, View and Edit screens) under the Screen Scheme to ensure the field is present.  You need to be a System Admin to do this however.
thanks, thats why I was not finding it.
