  • Community
  • Q&A
  • Jira
  • Questions
  • Best and clean way to move a JIRA project from a JIRA software site to another JIRA software site
Ahmed ElMalatawy June 25, 2022
We have 2 active JIRA software sites and we need to move an existing JIRA project with its all sprints/Epics/Stories/Issues/sub-tasks/attachments from one of our JIRA software sites to the other active JIRA Software site. So what is the best and clean way to do so smoothly?
Thanks.
5 votes
Walter Buggenhout
Hi @Ahmed ElMalatawy and welcome to the Community,
The best and cleanest way is most likely to uses the Cloud to Cloud Migration Assistant. You can find the steps and an overview of available methods through this support article.
Hope this helps!
Thanks @Walter Buggenhout . I will try to follow this support article
Ahmed ElMalatawy June 26, 2022
I successfully migrated the project using your provided support article .
