Can i execute a Script using Automation for JIRA?
Sunil Kumar August 9, 2022
Can i execute a script using automation for JIRA at a certain time or Cron.
Sunil
Tansu Akdeniz
Hi @Sunil Kumar
Welcome to the community.
There is "Run a script" function in automation which may help you.
Sunil Kumar August 10, 2022
Hi Akdeniz,
I saw the option but getting an error no plugin available and shows deprecated for us.
Any idea why?
Sunil
Sarah Kladstrup
I have seen the ScriptRunner option not load after updating both plugins. Atlassian's official suggest to me was to disable and re-enable ScriptRunner and that does seem to work.
Sunil Kumar September 1, 2022
Hi Sarah,
The option seems to be working as expected now. Thank you for the solution.
Sunil
Pramodh M
Hi @Sunil Kumar
It's a no code automation feature
May I know what feature you looking to achieve, may be we can look if it achieved through available trigger, condition, and actions
Hi Pramodh,
Thank you for the wishes,
I am trying to execute a script every 15mins in JIRA. Is that possible without using jobs functionality in script runner as there is bug.
Sunil
Sarah Kladstrup
Yes! There's a "Scheduled" trigger option, and you can click on a link that says, "use cron expression" and it will display as follows:
Sunil Kumar August 11, 2022
Hi Sarah,
But I want to add a script after the scheduling option which is deprecated right now.
Sunil
