I have two issues in jira that are linked through an issue link. I want to be able to use jira automation to detect when a change happens to a field. For example, let's say I have a field called due date. When the field changes for a specific issue type, I to compare that field with the issue it is linked to, and if the date is later than the issue it is linked to, I want to copy that value to the issue it is linked to.
