Hi there, we manage to connect to Jira using Jira_PowerBI_ContentPack.pbit. It works great and we can see all the issues and information. However, we are not able to see the comments on issues. Where is this located and how i can change the power query below:
let Source = FetchPages("", 100), #"Expanded Column1" = Table.ExpandRecordColumn(Source, "Column1", {"expand", "id", "self", "key", "fields","comment"}, {"expand", "id", "self", "key", "fields","comment"}), #"Expanded fields" = Table.ExpandRecordColumn(#"Expanded Column1", "fields", {"issuetype", "timespent", "project", "fixVersions", "customfield_10110", "customfield_10111", "aggregatetimespent", "resolution", "customfield_10112", "customfield_10113", "customfield_10114", "customfield_10104", "customfield_10105", "customfield_10106", "customfield_10107", "customfield_10108", "customfield_10109", "resolutiondate", "workratio", "lastViewed", "watches", "created", "priority", "customfield_10100", "customfield_10101", "customfield_10102", "customfield_10103", "labels", "timeestimate", "aggregatetimeoriginalestimate", "versions", "issuelinks", "assignee", "updated", "status", "components", "timeoriginalestimate", "description", "customfield_10006", "customfield_10009", "aggregatetimeestimate", "summary", "creator", "subtasks", "reporter", "customfield_10000", "aggregateprogress", "customfield_10001", "customfield_10004", "customfield_10115", "customfield_10116", "customfield_10117", "environment", "customfield_10118", "customfield_10119", "duedate", "progress", "votes", "parent", "customfield_10005", "customfield_10007", "customfield_10008", "customfield_10002", "customfield_10003"}, {"issuetype", "timespent", "project", "fixVersions", "customfield_10110", "customfield_10111", "aggregatetimespent", "resolution", "customfield_10112", "customfield_10113", "customfield_10114", "customfield_10104", "customfield_10105", "customfield_10106", "customfield_10107", "customfield_10108", "customfield_10109", "resolutiondate", "workratio", "lastViewed", "watches", "created", "priority", "customfield_10100", "customfield_10101", "customfield_10102", "customfield_10103", "labels", "timeestimate", "aggregatetimeoriginalestimate", "versions", "issuelinks", "assignee", "updated", "status", "components", "timeoriginalestimate", "description", "customfield_10006", "customfield_10009", "aggregatetimeestimate", "summary", "creator", "subtasks", "reporter", "customfield_10000", "aggregateprogress", "customfield_10001", "customfield_10004", "customfield_10115", "customfield_10116", "customfield_10117", "environment", "customfield_10118", "customfield_10119", "duedate", "progress", "votes", "parent", "customfield_10005", "customfield_10007", "customfield_10008", "customfield_10002", "customfield_10003"}), #"Expanded components" = Table.ExpandListColumn(#"Expanded fields", "components"), #"Expanded components1" = Table.ExpandRecordColumn(#"Expanded components", "components", {"name"}, {"components.name"}), #"Expanded fixVersions" = Table.ExpandListColumn(#"Expanded components1", "fixVersions"), #"Expanded fixVersions1" = Table.ExpandRecordColumn(#"Expanded fixVersions", "fixVersions", {"name"}, {"fixVersions.name"}), #"Removed Columns" = Table.RemoveColumns(#"Expanded fixVersions1",{"expand"}), #"Filtered Rows" = Table.SelectRows(#"Removed Columns", each [id] <> null and [id] <> ""), #"Expanded issuetype" = Table.ExpandRecordColumn(#"Filtered Rows", "issuetype", {"name", "subtask"}, {"issuetype.name", "issuetype.subtask"}), #"Renamed Columns" = Table.RenameColumns(#"Expanded issuetype",{{"issuetype.name", "issuetype"}, {"issuetype.subtask", "isSubtask"}}), #"Expanded project" = Table.ExpandRecordColumn(#"Renamed Columns", "project", {"id", "key", "name"}, {"project.id", "project.key", "project.name"}), #"Expanded watches" = Table.ExpandRecordColumn(#"Expanded project", "watches", {"isWatching"}, {"isWatching"}), #"Expanded priority" = Table.ExpandRecordColumn(#"Expanded watches", "priority", {"name"}, {"name"}), #"Renamed Columns1" = Table.RenameColumns(#"Expanded priority",{{"name", "priority"}}), #"Removed Columns2" = Table.RemoveColumns(#"Renamed Columns1",{"customfield_10102"}), #"Expanded labels" = Table.ExpandListColumn(#"Removed Columns2", "labels"), #"Removed Columns3" = Table.RemoveColumns(#"Expanded labels",{"labels", "versions", "issuelinks"}), #"Expanded assignee" = Table.ExpandRecordColumn(#"Removed Columns3", "assignee", {"name", "emailAddress", "displayName", "active"}, {"assignee.name", "assignee.emailAddress", "assignee.displayName", "assignee.active"}), #"Renamed Columns2" = Table.RenameColumns(#"Expanded assignee",{{"assignee.displayName", "assignee"}, {"resolutiondate", "resolution date"}}), #"Expanded status" = Table.ExpandRecordColumn(#"Renamed Columns2", "status", {"name", "statusCategory"}, {"status.name", "status.statusCategory"}), #"Expanded status.statusCategory" = Table.ExpandRecordColumn(#"Expanded status", "status.statusCategory", {"colorName", "name"}, {"status.statusCategory.colorName", "status.statusCategory.name"}), #"Removed Columns4" = Table.RemoveColumns(#"Expanded status.statusCategory",{"subtasks"}), #"Expanded reporter" = Table.ExpandRecordColumn(#"Removed Columns4", "reporter", {"name", "emailAddress", "displayName", "active"}, {"reporter.name", "reporter.emailAddress", "reporter.displayName", "reporter.active"}), #"Expanded aggregateprogress" = Table.ExpandRecordColumn(#"Expanded reporter", "aggregateprogress", {"progress", "total"}, {"aggregateprogress.progress", "aggregateprogress.total"}), #"Expanded progress" = Table.ExpandRecordColumn(#"Expanded aggregateprogress", "progress", {"progress", "total"}, {"progress.progress", "progress.total"}), #"Expanded votes" = Table.ExpandRecordColumn(#"Expanded progress", "votes", {"votes"}, {"votes.votes"}), #"Expanded parent" = Table.ExpandRecordColumn(#"Expanded votes", "parent", {"id"}, {"parent.id"}), #"Changed Type" = Table.TransformColumnTypes(#"Expanded parent",{{"resolution date", type datetimezone}, {"created", type datetimezone}, {"updated", type datetimezone}}), #"Inserted Date" = Table.AddColumn(#"Changed Type", "Date", each DateTime.Date([resolution date]), type date), #"Renamed Columns3" = Table.RenameColumns(#"Inserted Date",{{"Date", "Resolution Day"}}), #"Inserted End of Week" = Table.AddColumn(#"Renamed Columns3", "EndOfWeek", each Date.EndOfWeek([Resolution Day]), type date), #"Renamed Columns4" = Table.RenameColumns(#"Inserted End of Week",{{"EndOfWeek", "Resolution Week"}}), #"Inserted Date1" = Table.AddColumn(#"Renamed Columns4", "Date", each DateTime.Date([created]), type date), #"Renamed Columns5" = Table.RenameColumns(#"Inserted Date1",{{"Date", "Created Day"}}), #"Inserted End of Week1" = Table.AddColumn(#"Renamed Columns5", "EndOfWeek", each Date.EndOfWeek([Created Day]), type date), #"Renamed Columns6" = Table.RenameColumns(#"Inserted End of Week1",{{"EndOfWeek", "Created Week"}}) in #"Renamed Columns6"
Appreciate your help. Thanks!
Hi @darren.tan ,
in order to retrieve comments you need to use a specific API https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-comments/#api-rest-api-3-issue-issueidorkey-comment-get
Comments, in fact, are not a field of a ticket.
Hope this helps,
Fabio
