Relationships between issues:
I want to automate the process so that when a Task in Project B is linked to an Idea in Project A, the following happens:
Here is my Audit log and automation:
Here are the fields:
Okay after some digging, I've solved my own problem. Sharing the solution. I don't think I need to refetch, but I wanted to see it in the audit log.
the issues, but i did that for an audit purpose. I think I can remove it.
