Create Custom Fields for Issue Types for JIRA Project Template Plugin
Tanner Reese June 8, 2018
While creating a JIRA Project Template Plugin using this tutorial (https://developer.atlassian.com/server/jira/platform/creating-a-project-template/#step-5-set-up-the-json-configuration-file), how do you add custom fields and screens to an issue type?
The tutorial code will create a custom issue type which provides only the default screen and fields when you go to create an issue.
Prakhar Srivastav {Appfire}
June 8, 2018
Hi @Tanner Reese
You need to define Field Configuration Scheme. Here you can associate an issue type to a Field Configuration. You may need to create new Field Configuration based on your requirement.
Regards
Prakhar
