Create an Issue (from another project) within a Create Issue screen
Pamela Horne September 5, 2019
Is there a way I can have a field on my Create issue screen for my project, that would allow me to open another create issue screen for another project?  It would almost be like a sub-issue, and they would hopefully be linked?
Julie d'Antin [Elements]
Hi @Pamela Horne ,
You might want to check out some of the apps on the Marketplace to see if they can help. My team makes Elements Copy & Sync, which will let you copy and link issues. If you have any problems, don't hesitate to contact the Support Team.
Laura
Michael Thompson
September 5, 2019
To the left of the Create button is a checkbox to Create another. If you check that box before clicking Create, the Create Issue window will remain open with a message at the top telling you the issue number for the one you just created. You can then change the project field and it should flip to that project's Create screen.
However, unless you have a Linked field in your new create screen, the issues will not be linked to each other. You'll need to do that manually.
