Does anyone use JIRA for medical device Complaint Management?
Brenda Kelly
January 17, 2020
Currently working in the RUO space, but actively developing the QMS infrastructure to support medical device (ISO 13485 / 21CFR820)
We currently use JIRA's issue posting and tracking for development and troubleshooting activities, but have primarily paper-based QMS processes with an electronic document management system (hoping to convert to full eQMS as well).
I've done some initial research into the JIRA addon apps (confluence, comala workflows and publishing), which look like they would capture the majority of the ISO13485 and 21CFR part 11 compliance.
However, I haven't seen any pages with anyone specifically using JIRA workflows to track things like complaint management (Initial evaluation, testing, risk assessments, impacts, tracking to associated complaints/known issues, tracking to product requirements, escalation to CAPA, Adverse Events, etc.)
It seems like this is something that could be done with the added functionality with the electronic signatures and audit trails, and the separate "project" spaces seem like they could be configured to fulfill customized workflows based on the QMS requirements.
Is this something that anyone else has tried? Anyone used this with the new greenlight partnership?
Thank you!
2 accepted
Ste Wright
Hi @Brenda Kelly
The answer will be "sure" - like with a lot of business areas, Jira can be configured to more specific industries. Its flexibility ensures you can have workflows, screens, etc which meet the needs of your team.
Admittedly I've not worked in the medical device industry so I don't have any specific knowledge here - but you could do a discovery inhouse to decide how to setup Jira.
Or if you're looking for advice on apps - this answer has some good suggestions, and mentions these apps which look specific to your industry :)
Ste
Craig Schwarze _ProjectBalm_
Hi Brenda,
Some medical device manufacturers use our software to track product risks -
https://marketplace.atlassian.com/apps/1213146/risk-register
kind regards,
Craig Schwarze
5 votes
Marion Lepmets _SoftComply_
Hi @Brenda Kelly
we have joined forces with Comalatech in developing FDA 21 CFR 11 compliant solution for Confluence. It extends the ISO13485-based SoftComply eQMS with FDA compliant document approval, CAPA, training and change request workflows (built on Comala Document Management and Comala Publishing) and compliant access management. The solution is called MediCompli - https://softcomply.com/medicompli/. You can read more about its features -https://softcomply.com/comparison-of-softcomply-eqms-medicompli-solution/.
To automate ISO14971 compliant medical device risk management we have developed the SoftComply Risk Manager apps
We also support medical device companies in automating regulatory compliance on Atlassian stack - https://softcomply.com/services/.
In case of any questions, please drop us an email - info@softcomply.com
5 votes
Al
Hi Brenda
We started with a paper-based Quality Management System (QMS) certificated to ISO 13485:2013. However, since we focus on development of software as a medical device I ended up using Atlassian products as a business framework and built an eQMS to satisfy ISO 13485:2016 and FDA 21 CFR 820. We've been using this validated system since 2015, had many external audits with no paper in sight.
So, you are right it is entirely possible using appropriate addons and some effort to configure.
JIRA - issue types for requirements, NC, CAPA, complaints, changes, risk, etc each with their own workflow.   There are of course a number of addons to support this, including ALM Structure which enables traceability, planning, etc.
Confluence - Document wiki spaces which links (pulls in) jira issues. Critical to have Comala Document Management, or similar, which applies document workflows, tailored to you SOPs.
Service Desk - provides customer front end to support complaint handling and pot market surveillance.
Audit trail is inherent and a system fully compliant with EU GDPR, US 21 CFR part 11 and HIPAA can be developed.
I hope this helps
Al
Michael M. April 16, 2021
Hi @Al ,
I just found your answer when googling for "JIRA ISO13485". Great! Would you be available for a chat on your experience?
We're currently struggling with using JIRA to trace user requirements in MDR / ISO 13485. We feel like JIRA should be capable of supporting us - but don't see the way currently. It sounds like you've done it.
Appreciate your answer,
Michael.
Like Wade Metzler likes this
Al
Hi Michael
Yes, indeed.
You should consider jira issues as records within your QMS.  In that way you can create an issue type for each record needed, e.g complaint, NC, CAPA, and so on.
You do need to have admin access to customise jira and confluence.
(See also other responses from Soft Comply and RadBee).
For requirements you can use any built-in issue type, or create a specific Requirement or Sub-requirement if desired to represent the functional requirements.  All jira issues can be linked, e.g. parent  / child, relates to, etc. Requirements can therefore be linked to risks, tests, design, etc to provide full traceability.
All jira issues can, of course, also be pulled into Confluence pages so full specification documents can be created using the jira requirements (and other issues) to build everything required for technical file with appropriate approvals.
Al
Michael M. April 19, 2021
Hi @Al ,
thanks a lot for your answer - that helped already a lot. We're aware of the QMS, complaint, NC and CAPA handling capabilities within JIRA.
We're stuck however with the traceability aspects. We need a way to trace requirements from the design level down towards the technical design document levels. We're working in a SCRUM model where we separated the product design work (product definition) from the product build work (product execution). Now, our product owners specify their epics and stories and hand it over to product execution for a two weeks sprint. We're seeing some issues with the traceability of the specs produced by the product owners - especially if they're modified (user centric approach!) during product execution. We thought to solve this by documenting aspects in Confluence - but ended in a copy-past nightmare. Any idea on how to tackle this? Maybe a specific tool in mind?
We're on the cloud version and have full admin rights.
Thanks a lot,
Michael.
Matteo Gubellini _SoftComply_
April 20, 2021
Hi @Michael M.
We can help you with the reporting in Confluence. Feel free to reach us directly, you can also check some traceability-related videos here:
https://www.youtube.com/channel/UCYx5Z_IDQhA8QdXGcffnESg
Regards
Matteo
4 votes
February 8, 2020
Hello everyone,
We have recently launched a service to provide a fully 21 CFR 11 compliant turnkey solution based on Atlassian tools. Check this if you are interested.
We can also help you set it up yourself in your own server instance if you prefer.
We also have different Apps for Risk Management in Jira, specifically for the Med Tech sector. Link below:
Matteo
Ally Lancaster
Hi @Matteo Gubellini _SoftComply_ , with the announcement of Atlassian Server EOL I am wondering if you believe compliance is achievable using Atlassian Cloud?
October 21, 2020
Hello @Ally Lancaster ,
Atlassian will end selling new Confluence and Jira Server licenses in February 2021 and they will end supporting Server apps in February 2024.
Companies already on Server will be supported for the next three years and, even after that, the system will still run the same, even without updates from the App vendors and Atlassian.
We believe companies considering migrating to Cloud in the next 3 years will have the possibility to do so; we at Softcomply with our partners we are assessing all the requirements and some vendors are already working to release Cloud apps to bridge the compliance gaps.
We'll keep you posted.
Like # people like this
Philippe BARON September 27, 2023
We have succesfully implemented Complaints through Jira Service Management with few major avantages :
  1. Customers claims through the portail without license
  2. Customers claims through the web page of the portal or generic email, with capability to follow their requests
  3. SLA is native with JSM, and mandatory from a regulatory perspective
  4. JSM is natively integrated with Jira and Jira Asset Ma;nagement to link claims to a asset ( product configuration )
  5. Plus all the Collaborative features of Jira
Hope it helps.
Erez Kaminski -Ketryx-
Hi Brenda, there are many companies out there that use Jira for complaint management and post-market surveillance. Jira is a great issue-tracking environment that provides a great ecosystem of integrations to receive complaints (Salesforce, Zendesk, etc.) and different workflows to process and track them. However, FDA and EU MDR have quite strict requirements for complaint management. There are a few challenges you're going to face:
  1. Creating the right issue types, and workflows
  2. Part 11 compliant electronic signatures
  3. Maintaining a validated system for complaint management (and all the documents!)
  4. Tracing complaints to changes and actions taken
We have recently released Ketryx to the Atlassian marketplace to resolve all the issues above and remove the burden of configuring, managing, and validating Jira from your team. You can try it out here.
Elisa Vasta June 10, 2024
Hey Erez.
can I use Ketryx for free? I don't find any information on the marketplace.
Philippe BARON June 10, 2024
Hello Elisa,
I will recommend to have a look to Jira Service Management to implement a complaint process, as the portail is "free" for customer, only  Agent access need subscription. You can easly design your web portal, as well to implement SLA, route to Quality Ticket implemented in Jira & Confluence, etc.  And the more important, keep track of all communications with your customer.
Best regards.
Elisa Vasta June 18, 2024
Thanks for your input!
For complaint handling, I think I'll use it for sure!
Now I am trying to see how to integrate the CAPA process too. Which kind of JIRA project do you suggest to use for this case and which specific JIRA product (Jira Software Man, Jira Work Man....)?
Hi @Elisa Vasta Ketryx isn't free, but it does solve a lot of these problems, including CAPA management and reporting. If you are with a smaller medical device company, we have packages to help you with that as well! Please feel free to try it out at app.ketryx.com. It takes minutes to set up, and you can do anything you need in the 13485, 14971, and 62304 world!
Rina Nir
Hello @Brenda Kelly
Yes, the idea to manage Complaints process in Jira is a viable one, and the same is true for some of the other classical Quality processes (i.e. CAPAs and Deviations management, Suppliers management).  If you use the Server or Data Center platforms you can indeed achieve full GAMP 5 and CFR 21 part 11 compliance.
The approach is especially powerful if the organisation already uses Jira for other processes (software development). Bringing Quality processes into the platform where everyone are anyways, is a very effective way to make more people engage fully with these processes and reduces friction overall.
These are my favorite 'go to' Apps when we do these type of implementations (which is basically our bread and butter):
On Jira:
1. InLabs Electronic Signatures
2. Midori's Better PDF
3. ScriptRunner, JSU. JMWE, JWT (For all those nifty automations)
4. Structure for Jira (ALM) --> essential if you do Design Controls in Jira
5. ProjectBalms Risk Register --> For risk management
6. Xray Tests Management --> For Design Controls
On Confluence, In case you do Controlled Documents in Confluence:
1. Scroll PDF Eporter
2. Comala Document Management
3. Comala Publishing
4. Comala Metadata
5. Read&Understood Training Genius (Disclosure: this is our App)
Hope this helps,
Rina
(Thanks @Dave Rosenlund _Trundl_ for the shout-out)
Ally Lancaster
Hi @Rina Nir , with the announcement of Atlassian Server EOL I am wondering if you believe compliance is achievable using Atlassian Cloud?
Ally
Hi, @Brenda Kelly.  Adding to what others have said, there's at least one Atlassian Solution Partner who specializes in this area exclusively. They are called @RadBee. There may be others, too. I just happen to be personally aware of this one.
-dave [ALM Works]
