Hi, all
In our setup we have 2 weeks sprints, so I assume that all our Project types s'be <Scrum Soft Development> type.
At the same time that agile Workflow doesn't work for our work, I tried to add another status CODE REVIEW on project level with ALL transitions and I can see it from there with Transitions for each status, but this status is not reflected in Boards view, it still show only 3 statuses. And If I click View Workflow from issue I have that status CODE REVIEW without transition, so basically it's not active in this project type.
On the board I have those 3 statuses:
TO DO
IN PROGRESS
DONE
I'm probably missing some basic stuff, is this the only valid wflow for Scrum agile project. I see that Basic Software Dev project type has Wflow which works OK for us (it has IN REVIEW status). Is there a way to produce workable setup for our case? I'm preparing demo for our team and bit lost. We would like to be on timely sprints and have Basic Soft Dev workflow and has board view which will display all issue by status.
Tx if you can help me.
M
Or can I put issues assigned to Basic Software Dev project to BackLog, Sprint ??
** there is really no option to change our desired workflow, that it's in stone:-)
TO DO (or Open)
IN PROGRESS
IN REVIEW
DONE
