Help me with proper dependency solution to use jira-rest-java-client 2.0.0-m2 or olderone
Tarun Kumar September 27, 2018 edited
dependencies from maven repo for Gradle:
wildfly version : wildfly-10.0.0.Final
ERROR [org.jboss.resteasy.resteasy_jaxrs.i18n] (default task-60) RESTEASY002010: Failed to execute: javax.ws.rs.NotFoundException: RESTEASY003210: Could not find resource for full path: http://localhost/xyz/xyz/xyz
 at org.jboss.resteasy.core.registry.ClassNode.match(ClassNode.java:75)
at org.jboss.resteasy.core.registry.RootClassNode.match(RootClassNode.java:48)
at org.jboss.resteasy.core.ResourceMethodRegistry.getResourceInvoker(ResourceMethodRegistry.java:445)
at org.jboss.resteasy.core.SynchronousDispatcher.getInvoker(SynchronousDispatcher.java:257)
at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:194)
at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:221)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:85)
at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131)
at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:284)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:263)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:174)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:202)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:793)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
mamer_atlassian
October 11, 2018
Hi Tarun,
Have you looked at the below discussion. The dependencies mentioned in Joe Clark's post works fine for me.
https://community.atlassian.com/t5/Jira-questions/JIRA-REST-client-simple-example/qaq-p/464118
Tarun Kumar October 11, 2018
can u provide gradle dependencies which will compatible with wildfly10 ?
mamer_atlassian
October 12, 2018 edited
Hi Tarun,
I am not a gradle or wildfly10 user. However, you can see the equivalent gradle dependency in the maven repository link under the gradle tab:
You may also find this useful:
Muaamar
Tarun Kumar October 14, 2018
Thanks Muaamar,
yeah i tried this. It is working fine alone but not compatible with my application which is running on wildfly 10 . and it is raising error on resteasy and undertow which is present with wildfly10.Is there internal dependency with resteasy or any other which will affect resteasy?
i tired almost all versions of jira-rest-java-client ,jira-rest-java-client-core and jira-rest-api.All are causing same issue.
if you know help me.
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
