Help on JIRA as Test case Management.
Kailash Pathak February 11, 2014
Hi Bob,
I am using JIRA as Test case management tool in my current project by using JiraCli to import the data into JIRA from .csv file.
After Importing Test case i run all my Test case in JIRA till end.
My problem:
When any Test case Fail i want on click on "Fail" Bug screen should be open. Currently i have to open new screen (Bug) in different Tab or Window.
As Step Test case "Fail" i needed following Field in New Screen ::
-Bug Summary
-Priority
-Components
-Affects Versions
-Fix Versions
-Assignee
-Reporter
-Description
-Browse option (For Attachment)
I hope i as JIRA Admin design transition screen with above field ?
Thanks a Lot for your help in advanced.
Kailash
Nic Brough -Adaptavist-
February 11, 2014
