I am having issues getting the screen layout to change. This is my first time creating anything in JIRA (I am excited), but cannot get this to layout as I would like it. I have attached the current view and a view marked up with how I would like it to look.
Thank you.
Hi Preston,
Fields are always rendered one after the other in the order in which they are defined in the Screen configuration.
It is not possible to place fields next to each other in a screen; you can however, use tabs to organise the fields logically within a screen.
