Help with Scriptrunner - Parent issue not transitioning when sub-task transitions
Alex Cumberland
March 2, 2021
ScriptRunner 6.18.0
Jira Server 8.13.1
The logs show no issues and displays the values that I expect but the parent stays in the "Open" status.
The sub-task and parents use the same workflow.  The transition that I am trying for the parent is "Start Progress" (transition id = 4) which would put it in status "In Progress" (step id = 3) from "Open" or "Reopened" status.
I am using the following script that is the last step in the post-functions:
import com.atlassian.jira.bc.issue.IssueService;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.workflow.TransitionOptions;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.project.Project;
// Logging Imports
import org.apache.log4j.Level
import org.apache.log4j.Logger
log = Logger.getLogger("console")
log.setLevel(Level.DEBUG)
def Project project = issue.getProjectObject()
Integer actionID = 4; // Transition ID value
log.debug "project key: " + project.key;
log.debug "issue key: " + issue.key;
log.debug "issue Type: " + issue.issueType.name;
// Only want to perform for sub-tasks in the OK Project
if (project.key == "OK" && issue.issueType.name == "Sub-task") {
IssueService issueService = ComponentAccessor.getIssueService();
// Get the userID that is logged in currently
ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
// Get the parent issue object
MutableIssue parent = issue.getParentObject() as MutableIssue
// Check the status of the parent object
def isValidSubTaskStatus = parent.status?.name in ['Open', 'Reopened']
// If the parent status is valid, then we want to transition the parent
if (isValidSubTaskStatus) {
TransitionOptions transitionOptions = new TransitionOptions.Builder()
.skipConditions()
.skipPermissions()
.skipValidators()
.build()
IssueService.TransitionValidationResult result = issueService.validateTransition(currentUser,
parent.getId(),
actionID,
issueService.newIssueInputParameters(),
transitionOptions)
Alex Cumberland
March 2, 2021
Figured out the issue and was a real self head smack moment.
The script is fine except it does not have a step to do the actual transition.
Needs the following Code after the Validate Transition step:
if (result.isValid()) {
issueService.transition(currentUser, result);
Doing this will then actually fire the transition on the parent.
SERVER
VERSION
8.13.1
atlassian, jira cloud certification, managing jira projects, jira project administration, jira cloud exam, atlassian certification, agile project management, jira workflows, jira permissions, jira training, jira cloud skills, atlassian learning
Become a Certified Jira Service Project Expert 🦸🏻‍♂️
Validate your expertise in managing Jira Service Projects for Cloud. Master configuration, optimize workflows, and manage users seamlessly. Earn global 🗺️ recognition and advance your career as a trusted Jira Service management expert.
Get Certified! ✍️
