Help with associating a Issue Type Screen Scheme with a project
Marcus O_Brien
I have set up a new Bug Issue Type Screen Scheme, and now want to associate it with my project. It should allow me to have fields for the bug type only, and I can use them in all 3 operations.
I need help to add my new issue type screen scheme to to my project - its only for a bug issue type, so I presume the other types eg story/task/epic will retain what they are currently using ?
Marcus
Airbus Driver
July 8, 2021
Ok, let's see what you have done so far;
  • Created a new Screen and configured it according to your needs
  • Created a new Screen Scheme and associated the screen with all 3 operations
  • Created a new Issue Type Screen Scheme and associated the issue type of 'Bug' with the Screen Scheme
What's left to do;
  • Navigate to your project and then Project settings
  • Go to Issue types
  • Click on 'Actions' in the top right and then choose 'Use a different scheme'
  • Choose the Issue Type Screen Scheme that you created for your 'Bug'
It will only apply to issue type 'Bug' and nothing else. All other issue types will retain what they are using.
