Help with [jira.imports.project.DefaultProjectImportPersister] Unable to create issue with key
Chris MacLean December 30, 2014
Has anyone seen this issue or can give me a lead on it?
2014-12-30 14:51:19,879 ProjectImport: CreateIssues-10 ERROR chris.maclean 891x2686x1 ikor7y 66.11.145.90 /secure/admin/ProjectImportSummary.jspa [jira.imports.project.DefaultProjectImportPersister] Unable to create issue with key 'COR-189'.
com.atlassian.jira.external.ExternalException: Unable to create issue: The Last Modified Date of an incident is misleading to customers ---
at com.atlassian.jira.external.ExternalUtils.createIssue(ExternalUtils.java:245)
at com.atlassian.jira.imports.project.DefaultProjectImportPersister.createIssue(DefaultProjectImportPersister.java:146)
at com.atlassian.jira.imports.project.handler.IssuePersisterHandler$1.run(IssuePersisterHandler.java:77)
at com.atlassian.jira.util.concurrent.BoundedExecutor$1.run(BoundedExecutor.java:50)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: com.atlassian.jira.exception.CreateException: com.atlassian.jira.workflow.WorkflowException: java.lang.InterruptedException
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:648)
at com.atlassian.jira.external.ExternalUtils.createIssue(ExternalUtils.java:234)
... 6 more
Caused by: com.atlassian.jira.workflow.WorkflowException: java.lang.InterruptedException
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:920)
... 7 more
Caused by: java.lang.RuntimeException: java.lang.InterruptedException
at com.atlassian.jira.project.DefaultProjectManager$NextIdGenerator.getNextId(DefaultProjectManager.java:918)
at com.atlassian.jira.project.DefaultProjectManager.getNextId(DefaultProjectManager.java:217)
at com.atlassian.jira.project.CachingProjectManager.getNextId(CachingProjectManager.java:81)
at com.atlassian.jira.workflow.function.issue.IssueCreateFunction.execute(IssueCreateFunction.java:51)
at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1050)
at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:615)
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:879)
... 8 more
Caused by: java.lang.InterruptedException
at java.util.concurrent.FutureTask.awaitDone(Unknown Source)
at java.util.concurrent.FutureTask.get(Unknown Source)
at com.atlassian.jira.project.DefaultProjectManager$NextIdGenerator.getNextId(DefaultProjectManager.java:911)
... 15 more
Boris Berenberg
December 30, 2014
We would need to see the full stack trace associated with this to know what the issue is. If you have a valid support license, this may be better off handled in a support ticket. https://support.atlassian.com/
