Ho wto move an issue with Automation for Jira
Sebastian_Wenner November 5, 2018
how can I move an issue after a certain transistion to a second project with Automation for Jire?
I could only find a "clone issue" but not a "move issue".
Could you please either point out how to do that or is it just not (yet) there?
Sebastian
Manon Soubies-Camy
Hello @Sebastian_Wenner,
The action "Move issue" is indeed not available as of now, CodeBarrel shares a workaround here: Move an issue. Cloning and deleting an issue instead of moving it is usually the best solution.
If you'd rather script the move, I'd recommend to read this recent thread: Post Function to move an issue to another project.
Hope this helps!
- Manon
Thanks for the pointers. I missed that one on the documentation - my bad.
*thumbs.up*
Like Manon Soubies-Camy likes this
Yogesh Mude
November 5, 2018
Hi @Sebastian_Wenner
Welcome to the  Community!
This can not easy as you are thinking because every project has their own configurations like Workflow, fields, screens etc...
You can do with some custom script, power script etc add-ons.
