How do I enable a project admin to be able to create a project link from jira to confluence
DavidK April 19, 2016
I have setup a project and an associated administrator.  Though when they login, they can't perform a creation of a project link from JIRA to Confluence from the Project Administration page.  I can see that functionality as an admin but not as the specific project admin.
Steven F Behnke
April 19, 2016
What is the point of setting up a Project and Space link? There's zero functionality surrounding it.
I am using JIRA v7.1.2
Chander Inguva
April 19, 2016
Hi David,
             Which version of JIRA are you using ?
Reference: https://confluence.atlassian.com/jiracoreserver070/project-shortcuts-777015858.html
  • If the user is having JIRA Administrator global permission or Project Admin permission he should be able to add/edit link
Regards
Chander
Hi, thanks for responding
From the referenced page, I am not seeing the 'Select Add link in the project navigation sidebar.
Also from project administration page, under Settings, I don't see an 'Application Links' With a Configure Project Links link', like I do when I am logged in as a system admin.  I only see 'Repository Path'
