It is possible to search for parts of what is written in the summary field (with ~). I want to do the same thing for the FixVersion/s field. Is this possible?
In general my concern is, that I have Releases that have a specific nomenclature and I want to filter for the issues that are subordinated, based on parts of this nomenclature. Is there a possibility to do this without the use of Add-ons/labels etc.?
The ~ character is not supported for queries with fixVersion.
But you can use fixVersion in situations like these:
fixVersion in ("3.14", "4.2")
or
fixVersion = "hello"
Hope this answer your question!
This answers my question, but does not provide a solution. Too bad, that the Fix Version field cannot be accessed by the ~ character. This means there is no "Out-of-the-box"-Solution for just filtering for segments of the Release name, too bad, as Releases do not have any other attributes that can be filtered for.
This doesn't work for me, as the "IN" syntax requires an exact match, if you try to use partial, it doesn't work, in fact, you get a error that the Value you entered does not exists in fixVersion. The solution below, however, doesn't work .
I've just found out that this seems to work now:
fixVersion ~ "*keyword*"
Thank you Tomas!
Why would this syntax work for some and not others? It does not work for me.
Thank you! was missing the wildcard * before and after the keyworkd - that resolved my problem
Tks @Tomasz Drabik !
Not working for our version... will try later when we fully migrated to the Jira cloud
Is there any way to add the below
fixVersion ~ "*Q*"
in JIRA expression code?
the ~ can only be used in JQL for the fields that are defined as free text searchers, fix version is a select list field.
with scriptrunner you have a function that fits your needs
fixVersion in versionMatch("^RC.*")I guess the free addon SQL to JQL would work for you too (haven't try it)
Thank you for your answer. An addon sadly does not solve the problem, because it is not possible to intall them, even when they are free of charge, due to the Company's IT structure.
Ok, maybe you could do some workaround like copying the version value to a text field and filtering for this new field.
Yes, this was now the way to go. I wanted to avoid manual work, but unfortunately Atlassian does not provide an out-of-the-box solution (like in many other cases). Thanks for the support.
