How do I filter for parts of the FixVersion/s field?
Gero Kassen
It is possible to search for parts of what is written in the summary field (with ~). I want to do the same thing for the FixVersion/s field. Is this possible?
In general my concern is, that I have Releases that have a specific nomenclature and I want to filter for the issues that are subordinated, based on parts of this nomenclature. Is there a possibility to do this without the use of Add-ons/labels etc.?
3 votes
Alexander Ling
October 2, 2019
According to https://confluence.atlassian.com/jiracorecloud/advanced-searching-fields-reference-765593716.html?_ga=2.228522654.2094838208.1569828953-503707675.1567420743#Advancedsearching-fieldsreference-FixVersionfixVersionFixversion
The ~ character is not supported for queries with fixVersion.
But you can use fixVersion in situations like these:
fixVersion in ("3.14""4.2")
or
fixVersion = "hello"
Hope this answer your question!
Gero Kassen
This answers my question, but does not provide a solution. Too bad, that the Fix Version field cannot be accessed by the ~ character. This means there is no "Out-of-the-box"-Solution for just filtering for segments of the Release name, too bad, as Releases do not have any other attributes that can be filtered for.
Like # people like this
Mark Moore August 25, 2023
This doesn't work for me, as the "IN" syntax requires an exact match, if you try to use partial, it doesn't work, in fact, you get a error that the Value you entered does not exists in fixVersion.   The solution below, however, doesn't work .
Like Rudolf Arada likes this
16 votes
Tomasz Drabik
February 17, 2022
I've just found out that this seems to work now:
fixVersion ~ "*keyword*"
Jason Cox February 25, 2022
Works great!  I saw reports in other places that this solution doesn't work, but I just tested and it worked for me!  Thanks Tomasz!
Like hazel.digama likes this
Konstantin Demidov
July 26, 2022
Thank you Tomas!
Tomasz Drabik
November 13, 2022
Wilbert Bus January 10, 2023
Great, that worked too for me!
Thanks, I knew there had to be a way to do this...
Monica LaRue
November 6, 2023
Why would this syntax work for some  and not others?   It does not work for me.
Maryann Rieger
November 14, 2023
Thank you!  was missing the wildcard * before and after the keyworkd - that resolved my problem
Like Darren Shotam likes this
Leandro Pachega
September 11, 2024
Tks @Tomasz Drabik !
Rudolf Arada
March 4, 2025
Not working for our version... will try later when we fully migrated to the Jira cloud
Abhipsa Mohapatra
March 9, 2025
Is there any way to add the below
fixVersion ~ "*Q*"
in JIRA expression code?
Jan Sękara February 17, 2022
Great Tomasz, thanks for that!
fran garcia gomera
October 2, 2019
the ~ can only be used in JQL for the fields that are defined as free text searchers, fix version is a select list field.
with scriptrunner you have a function that fits your needs
fixVersion in versionMatch("^RC.*")
 https://scriptrunner.adaptavist.com/latest/jira/jql-functions.html#_projectmatch_componentmatch_versionmatch
I guess the free addon SQL to JQL would work for you too (haven't try it)
Gero Kassen
Thank you for your answer. An addon sadly does not solve the problem, because it is not possible to intall them, even when they are free of charge, due to the Company's IT structure.
fran garcia gomera
October 2, 2019
Ok, maybe you could do some workaround like copying the version value to a text field and filtering for this new field.
Gero Kassen
Yes, this was now the way to go. I wanted to avoid manual work, but unfortunately Atlassian does not provide an out-of-the-box solution (like in many other cases). Thanks for the support.
