How project Admins can create custom fields for their project
Sam Taylor
How project Admins can create custom fields for their project.
Avinash Bhagawati _Appfire_
Hi @Sam Taylor ,
With default configuration you will not be able to configure your requirement and you can delegated custom fields creation with help of below app.
https://marketplace.atlassian.com/apps/1219174/custom-field-for-project-admin-for-jira?hosting=server&tab=overview
Avinash
Leo Diaz - Deiser
Hi  @Sam Taylor
You have available in the marketplace Profields app. Profields gives you fields for Projects, and you can have any field type: Select List, Status, Text, etc...
Also, you have a Project Navigator where you can work with your projects!
Search, filter and organize your Jira projects with project custom fields
Yuval Gershfeld
Hey @Sam Taylor
In Methoda we created an add-on that allows project admins to seamlessly add/edit and control custom fields, values and screens. It's easy to use and user friendly.
See: https://marketplace.atlassian.com/apps/1221078/custom-fields-administrator-for-jira-project?hosting=server&tab=overview
