How to Hide Card in Project Management (Jira work Management Template) and use card in scrum board
ShivagariA May 29, 2024
Dears
Kindly help me how to hide from viewing  card  in Board of  Project Management and use in Scrum Bord
Nagabharana S
May 29, 2024
Hello @ShivagariA
The trick is to use the board filter efficiently, you can make changes to the board filter (JQL) to have the required issues displayed on your board.
I hope it helps. :)
Thanks @Nagabharana S
Here as my requirement is to hide sit bug fixing card  and visble in scrum board
