We want to mark all of our JIRA projects, depending on the sensitivity of the information it contains by a top banner or a specific color scheme (green-orange-red) per project.
Does anyone have an idea on how to I set this up using basic JIRA functionality (7.11.1) or through an add-on?
Thanks in advance for any suggestion.
Hello @Ruben Decocker,
Announcer for Jira should do the trick. You can also vote for this feature request, add yourself as a watcher to be updated, and check the workarounds: Change look and feel on a per-project basis.
Hope this helps!
- Manon
Hi Manon,
with Announcer I can indeed put a specific banner per project.
Formatting is rather limited at the time but the Wittified team is looking into it.
Thanks a lot for your help.
Ruben
