How to create a jira issue from postfunction using groovy through rest API
Vineela Durbha
I am trying to create an issue of a project from another project post function. I am trying to create it through rest api as below
import groovy.json.StreamingJsonBuilder
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import java.text.SimpleDateFormat
import java.text.DateFormat
import com.atlassian.jira.issue.comments.CommentManager
def baseURL = "http://localhost:8081/rest/api/2/issue/";
// localhost:8081 it`s the target instance
def authString = "admin:admin".getBytes().encodeBase64().toString();
def body_req = [
{ "fields":
"project":
"key": "XXXX"
"summary": "My Issue.",
"description": "Creating of an issue using project keys and issue type names using the REST API",
"PType": "CCCC",
"TSW": "XXXX",
"reporter":
"name": "sdurbha"
"issuetype":
"name": "Bug"
URL url = new URL(baseURL);
HttpURLConnection connection=(HttpURLConnection)url.openConnection();
connection.setRequestProperty( "Authorization", "Basic ${authString}" );
connection.requestMethod = "POST";
connection.doOutput = true;
connection.setRequestProperty("Content-Type", "application/json;charset=UTF-8");
connection.outputStream.withWriter("UTF-8") { new StreamingJsonBuilder(it, body_req) }
connection.connect();
I am neither getting an error nor the issue is being created. Can someone help me on this
zaharovvv_suek_ru
May 27, 2020 edited
1. I have the same problem, so I decided to create new project in Jira. And issue started to be created. The reason was that my json object to create issue did not have fields which are marked as **required**. Read more about required fields here. So try to create a new project without required fieds.
2. Then your "body_req" can be changed to:
def body_req = '''{
"fields":
"project" : { "key" : "E1" },
"issuetype" : { "name" : "Task" },
"summary" : "FooSummary",
"description" : "FooDescription"
"reporter": {"name": "yourJiraLogin"}
 3. In addition, try to see actual format of json for your Jira version. Sometimes, some fields have different formats. For example, component field should be put into square brackets:
"components": [
                "id": "10000"
In addition, you can read desired info about fields from the docs.
For example, you can get a list of all the projects from the following endpoint:
    http://localhost:8080/rest/api/2/project
After finding the project you want, you will need its ID or key. You will use this information to retrieve the issue types in this project:
http://localhost:8080/rest/api/2/issue/createmeta/{projectIdOrKey}/issuetypes
Once you find the appropriate issue type to use, you need to get the fields under this issue type. This endpoint will list the usable fields under the issue type.
http://localhost:8080/rest/api/2/issue/createmeta/{projectIdOrKey}/issuetypes/{issueTypeId}
My full code looks like this:
import groovy.json.JsonBuilder
import org.apache.log4j.Logger
import org.apache.log4j.Level
def log = Logger.getLogger("com.acme.CreateSubtask")
log.setLevel(Level.DEBUG)
def authString = "adminUser:adminPassword".getBytes().encodeBase64().toString()
def body_req = '''{
"fields":
"project" : { "key" : "S" },
def connection = new URL("https://yourjiraaddress/rest/api/2/issue/").openConnection() as HttpURLConnection
connection.setRequestMethod( "POST" )
log.debug("Hello, authString is ${authString}")
connection.getOutputStream().write(body_req.getBytes("UTF-8"))
def postRC = connection.getResponseCode();
println(postRC);
if(postRC.equals(200)) {
println(connection.getInputStream().getText());
log.debug("The response is ${connection.getInputStream().getText()}")
Antoine Berry
Hi @Vineela Durbha ,
Why use Rest-API over standard groovy script ?
Tarun Sapra
Hello @Vineela Durbha
Why are you using REST APIs if the target project in which you want to create an issue exists in the same instance?
You can very easily use the Jira Java API to easily create an issue in another project in the same Jira instance. Generally , REST APIs is used to create issues in remote instances.
Using Jira Java API, it's very simple as described here
https://developer.atlassian.com/server/jira/platform/performing-issue-operations/#creating-a-new-issue
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
