How to create issues associated with issue links using direct HTML links in Jira Server?
Jack Song
September 11, 2024
Hello:
I'm trying to create Jira issues using HTML links, like the following URL shows. I also want to create a link to another issue in the same URL.
https://jira.company.com/secure/CreateIssueDetails!init.jspa?pid=26005&issuetype=1&summary=This+is+a+demo+summary&assignee=qian017&issuelinks-linktype=relates+to&issuelinks-issues=G01018-10
But after open it in the Web browser, there is no warning information. And the fileds of Linked Issues and Issue are not filled with the expected value.
So is it the correct URL to create issue links?
Dimitris Sylligardakis
September 16, 2024
Hi Jack,
Not sure if I understood correctly, but check if this URL works
https://jira.company.com/secure/CreateIssueDetails!init.jspa?pid=26005&issuetype=1&summary=This%2Bis%2Ba%2Bdemo%2Bsummary&assignee=qian017&issuelinks-linktype=relates%20to&issuelinks-issues=G01018-10
Quick step guide
1. URL Encoding:
  • Make sure that special characters in your summary and potentially other fields are properly URL encoded. For example, spaces should be replaced with + or %20. You can use online URL encoding tools to help with this.
2. Field Names:
  • Double-check that pid (project ID), issuetype (issue type ID), and assignee (username) are the correct field names for your Jira instance. These might vary depending on your configuration.
  • For the linked issues, the fields issuelinks-linktype and issuelinks-issues seem correct based on common usage, but again, confirm these are the exact field names your Jira expects.
3. Issue Key Format:
  • Ensure the issue key you're referencing in issuelinks-issues (e.g., G01018-10) is in the correct format for your Jira project.
