Hi! I'm using this request from the first answer. And everything works well. But it loads all rows from Jira (about 100 000) and it takes a lot of time to update a report.
Is there some possibility to filter data before it was loaded in Power BI?
For example, how to load issues for previous 6 months?
That should be done by Power Query, You should filter data from Power BI before loading.
