How to get users assigned to Jira Project and their corresponding Roles
jahanathan.saminathan December 19, 2022
My requirement is:
  • Fetch list of Users available in the Project
  • Fetch List of Roles assigned to Users
Unfortunately I am not able find any REST APIs for both of these operations !
Can you please help me. Thanks :)
6 votes
Mohamed Benziane
You need to use this API
rest/api/2/project/{projectIdOrKey}/role
you'll get all the role in your project then use this API to get all users that belong to this role
/rest/api/2/project/{projectIdOrKey}/role/{id}
https://docs.atlassian.com/software/jira/docs/api/REST/9.3.2/#api/2/project/{projectIdOrKey}/role
jahanathan.saminathan December 22, 2022
@Mohamed Benziane : Yes it worked ! thank you so much for your suggestion :)
May be Atlassian documentation should be updated for this Get Project Role REST API like "this will return the assigned list of users".
Like # people like this
Faiyaj Sarjekhan
May 22, 2024
They need to have a straightforward API which would return the user with associated project roles.
Felipe N Ribeiro July 14, 2025
it is also possible to use the same endpoint in v3, which follows the same structure:
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-project-roles/#api-rest-api-3-project-projectidorkey-role-get
Grace Tan Chia Me August 29, 2024
I have similar question on how to extract list of user and list of their respective roles in each of projects. Can i do without using API? Thanks
Mohamed Benziane
In jira cloud this not possible without API. In DC may be you can use the database to get the data you need.
Grace Tan Chia Me September 1, 2024
Thanks for responding! I'm referring Jira web (not Jira cloud). Please provide steps if possible. Appreaciate the help. Thanks a lots
