  • Community
  • Q&A
  • Jira
  • Questions
  • How to make custom fields mandatory using automation after meeting specific requirements in a Jira t
Sachin Guttala
2 accepted
5 votes
Fazila Ashraf
Hi @Sachin Guttala
Could you explain what you are trying to achieve?
With automation, you cannot make a field mandatory. You can use the field configurations or advanced forms for such requirements
Sachin Guttala
when the Issue type is TASK and custom field "Keyword" is "TSUP" then only field should mandatory
3 votes
Valerie Knapp
Hi @Sachin Guttala , thanks for your post.
If I understand correctly, you want to make the Time Spent field required during a transition. The best way to do this is probably with workflow validator as my fellow Community Leader @Trudy Claspill explains in this question - https://community.atlassian.com/t5/Jira-questions/How-to-make-quot-Time-Spent-quot-field-required-in-the/qaq-p/2249249
I would try to implement the solution she suggests in the workflow instead of using an automation.
Best wishes
Sachin Guttala
Hi @Valerie Knapp Thanks for the response, but when the Issue type is TASK and Keyword is TSUP then only field should mandatory
Valerie Knapp
Hi @Sachin Guttala , I agree with @Fazila Ashraf .
If something is possible, you would likely need to use an app, like Behaviours - https://docs.adaptavist.com/sr4jc/latest/features/behaviours/example-behaviour , not an automation.
Best wishes
Sachin Guttala
Thanks @Valerie Knapp
